Mi Tv Series in India
Sideload the app https://smartyoutubetv.github.io/ and see if you can watch youtube in 4k. This app allows you to manually select the 4k streams with different bitrates.
No...i'm already using it. It allows us to select 4K but TV chipset can't play them and stutters because lack of vp9 hardware decoding as i mentioned above. Max quality youtube uses in H264 format is 1440p. All 4K videos use vp9 compression in youtube
I would suggest whoever planning to buy Mi TV4 to invest another 12k and get a Nvidia shield TV. You can get everything out of the box with support for 4k. You can forget about formats and resolutions as shield will take care of it. 40k TV +12k Nvidia shield is a deadly combo
No...It won't or cannot support forever because Youtube encodes all 4K content in VP9 format and HDR in vp9.2 format. Chipset in MI Tv doesn't support either of the formats. Hence, it's only possible to watch youtube upto 1440p natively. That doesn't make the chipset bad. Intel's most powerful 6th gen chipset also cannot support vp9 hardware decoding because the tech is kinda new(Vp9 is only supported in Indtel 7th/8th gen). You can connect a HDMI 2.0 laptop or any streaming device to watch youtube in 4K.
Yes i am aware of that. I asked this because of a recent review on flipkart. So i am asking Mi TV owners if they received any update recently.:
"Very quick delivery with satisfied installation and demo by Jeev. Tv is awesome overall rating i give 5. Sound and picture clarity is superb. YouTube and hot star app are updated in the OS and able to play 4k content. Worth for budget families "
Only Hotstar app was added in a server side update. There wasn't any firmware update since a month.
Looks like that Dude got excited seeing a 4K logo. It simply isn't possible in Youtube. Flagship devices like Nvidia sheild TV also failed to do that feat of supporting Youtube HDR.
guys, what are your picture and backlight settings? pls share.
Each panel varies with each other. Start calibrating by keeping the TV in movie mode
Dynamic contrast and Dynamic Color- OFF
(Dynamic contrast blowing away highlights in HDR video and Dynamic color produces weird colors, So both should be set to off)
Then keep the backlight setting according to u'r room light(For a single tube light - Backlight at 45 for SDR video with adaptive Backlight(ABL) ON works for me. **Backlight should be always 100 for HDR video in any TV)
Start calibrating brightness, contrast, color of u'r panel using AVS HD 709 patterns and share here. I'm not sharing my settings yet because it would affect u'r decision because each panel differs.
Where can i get nvidia shield tv for 12k in india?? I need one, but cannot find it at this price
anybody has experience for purchase MI TV 55 inch from MI india for Delivery, Installation and after sale service. is it better than Flipkart. As I have experience with Jeeves for installation and they are careless people. I am worry because this is very delicate product.
Good news.. if specs better then current version. Not just voice remote. But picture clarity and durability. Will try tomorrow again to get it in flash sale.
Xiaomi Mi TV 4S 55-inch specifications - 2999 yuan
55-inch (3840 x 2160 pixels) 4K display with 178-degree viewing angle, 8ms dynamic response
1.5GHz quad-core Amlogic Cortex-A53 processor with 750MHz Mali-450 MP3 GPU
2GB RAM, 8GB internal memory
MIUI TV based on Android
WiFi 802.11 ac (2.4 / 5GHz), Bluetooth 4.2 LE, 3 x HDMI, AV, 2 x USB, 1 x Ethernet
Supports HDR 10 and HLG,H.264, H.265, Real, MPEG1/2/4, WMV3, VC-1
2 x 8W speaker, DOLBY AUDIO / DTS- HD audio dual decoding
For comparison,
Xiaomi Mi TV 4 specifications - 3999 yuan 4499 yuan
55-inch (3840 x 2160 pixels) 4K display with 178-degree viewing angle, 8 ms
1.8GHz quad-core Amlogic Cortex A53 SoC with up to 750MHz Mali-T830 MP2 GPU
2GB DDR4 dual-channel RAM, 8GB internal memory (eMMC 5.1)
MIUI TV with PatchWall AI based on Android
WiFi 802.11 a/b/g/n (2.4 / 5GHz) 2X2, Bluetooth 4.0 LE, Mi Port, 3 x HDMI 2.0, AV, 1 x USB 2.0 x 1, USB 3.0 x 1, Ethernet
Supports H.265 4K at 60 / 30 fps, H.265 1080P at 60 fps, H.263 1080P at 30 fps, MPEG1 / 2/4 DivX4 the VC-1 / WMV3 1080P at 60 fps, REAL 8/9/10 1080P at 30 fps
2x 8W speaker for DOLBY AUDIO, DTS-HD
So 4S is basically a little lower placed than 4 with some extra generation updates.
For comparison,
Thanks for comparison. I want to understand we should compare with costly part in tv.. ie. panel ? or general specification.
Hope this new tv will launch soon in india.
MI TV delivered yesterday by flipkart and installation was done same day. Picture quality is good, but sound is ok. ok.
1. IR cable is not include by flipkart. need to follow up with flipkart?
2. Please help for picture calibration.
3. website for download 4k movies and videos ?
4. 1 USB working fine with my HDD and 2nd is not working. so want to know its compability issue or port is not working ?
