Rain outage is a problem with Videocon D2H. The signal stops even before it starts raining. May be a bigger dish will solve the issue.
I dont have this issue . signal goes off only when heavy rain . May be signal strength and region matters
^^ True. The signal is lost even when it is cloudy. With my old reliance hd the signal was lost only on heavy rain.
Friends,
I'm looking for new HD Connection for my 55 inch LED/Lcd TV.
Since the screen size if huge, normal SD channel from Hathway STB is unbearable.
So looking for HD STB, that can provide good QUALITY on regional channels as well.
My requirement would be, Tamil Channels and HD channels. <Maximum channels is not the criteria, Quality must be good>
Kindle suggest, TATA SKY or Videocon ??
My D2H goes off only in heavy rains and that for at most 10 min. Seems to be a location related issue then.
10 mins is a big time :sad:. D2H tech guy tried increasing the signal strength and aligning the dish properly, but the result is the same. I doubt if it is region specific, i stay in the same city as you do. But overall i am finding D2H very good.
Can anyone who has joined D2h HD services recently, let me know the total cost for subscribing to the HD (1TB) recording box and ALL channels ?Also any one has also subscribed for an additional HD connection
has
I ask this as I am getting different amounts from their local dealers and their web site. Ranging from 5900?- to 11,200 for a SINGLE STB/subscription.
Thanks!
has
Thanks!
Do we have additional any advantage using the in-built HDD??STB
looks like around 6k difference when buying inbuilt 1Tera HDD...
instead we can buy 2k worth external HDD Recording STB rt? in that case we add any size HDD.
