bharath_rbk
Hey All,
I have been an avid reader in this forum and still making an attempt to gain a bit of knowledge of this audiophile world. Hadnt posted anything since becoming member, so thought this would be the right time to give a try and also to return favor.
Finally a month long (full time) project has almost come to an end of building a 7.1 dedicated home cinema with room size of 14x21 feet. Even though title says as Million Rupee, everything is done on a budget. All the equipment is chosen to keep under certain price, without skimping on acoustics and seating. Every aspect takes an equal share of its importance right from speakers to projector screen till carpet. Overspending on speakers without proper acoustics is the least thing we wanted. When it comes to finally watching movies along with friends or family, they will not bother what all components have gone in. It should not only sound great, there should be a wow factor!!
I have never come across Crystal Acoustics as a brand talked of and their impression in this forum yet. So, I suppose this would be first thread throwing some light on the first hand impression and opinion.
To cut a long story short, Crystal Acoustics has one of the best sounding speaker package which is also a THX Ultra2 certified which doesnt require robbing a bank.
Initial Impressions
* Well built, glossy piano black and black ash finish feels premium
* Floor standers has interesting Cabinet design with silk dome tweeters mounted on top (Seems to eliminate resonances inside the cabinet). They are little bright when paired with Denon X2000, but does its job great with the movies. Stereo performance is good with tonal clarity, high frequency comes out distinguishingly well but Lows are bit laid back I think.
* Center speaker build is again robust, rotating tweeters on top. Though its a single 7 woofer, a double bass reflex port packs some punch and vocals to be very clear.
* Rears speaker has dipole design sporting two reverse facing silk dome tweeters to be mounted on the wall which does a fabulous job of dispersing surround effects and incredible ambience. Of the entire surround speakers auditioned, this one seemed to best both in terms of performance and aesthetically pleasing for the value it comes. THX logo makes an icing on the cake.
* Sub-woofer from this package has been replaced by Velodyne EQ-Max 12, and there are already many opinions about this sub. I could tell only this much, it can literally kick you on the chest with its bass. The only reason to replace Crystal sub to Velodyne is the thought it would be bit underpowered for the larger area. May be a 7.2 Crystal package would have been stellar but significantly budget would also have been increased in terms of additional sub and 7.2 supporting AVR.
Below is the list of A/V equipment involved in this build and I have included the links for particular product in case if someone would want to know more information about them.
A/V Receiver Denon AVR-X2000
DENON AP | AVR-X2000
Floor Standers Crystal Acoustics T2-TX-T2SE-BL
Centre Speaker Crystal Acoustics THX-CT-BLA
Surround Speakers Crystal Acoustics THX-D-BLA THX (2 Pairs)
T2-7.1-UL Home Theater 7.1 THX Speaker System
Powered Subwoofer Velodyne EQ-MAX 12-Inch Subwoofer
EQ-Max 12 12" Powered Subwoofer by Velodyne
Projector Epson EH-TW6100 (Full HD/3D)
Epson EH-TW6100
Projector Screen Winger Fixed Frame 133
Fix Frame Projector Screen, Fixed Frame Screens, Fixed Screens, Manufacturers, Suppliers, Exporters, India
Blu Ray Player Pioneer BDP 450
BDP-450 |
Media Player/XBMC MINIX NEO X8-H Android 4.4 TV BOX
MINIX NEO X8-H - MINIX
Universal Remote Logitech Harmony 650
Harmony 650 Universal Remote Control - Logitech
Online UPS ETON E Series DX UPS -2 kVA
E Series DX UPS 1-20 kVA
Next post would be with lots of pics, for now I would like to leave one teaser...
Initial Impressions
Epson EH-TW6100
BDP-450 |
