MoFi Electronics - SourcePoint 8
allegra audio
Hyderabad
Allegra Audio is pleased to present the MoFi SourcePoint 8
Please contact us for a demo or for more details on our fantastic deals and pricing!
Email: [email protected]
Phone: +91 74166 66699 (WhatsApp)
MAKE YOUR HIGH-END AUDIO EXPERIENCES MORE PLEASURABLE: CLASS-LEADING SOUND AND A COMPACT FOOTPRINT
Renowned audio engineer Andrew Jones created the Mobile Fidelity Electronics SourcePoint 8 bookshelf loudspeakers to give anyone who wants the benefits of his signature two-way concentric driver design — reference-grade soundstaging, three-dimensional imaging, visceral punchiness, emotional expressiveness, hear-through clarity — the opportunity to have it in a unit that easily fits in most spaces. Sharing most of the same DNA as its bigger brother, SourcePoint 10, the 18 x 11.4 x 13.2-inch (HWD) SourcePoint 8 wraps class-leading sound, robust build quality, and elegant looks into a package that doesn't present the dimensional or aesthetic challenges of larger models.
As he did with SourcePoint 10, Jones devised SourcePoint 8 to appeal to music lovers of every stripe — and to play every kind of music with an aptitude off-limits to many speakers. Whether you prefer relaxing or aggressive fare, acoustic or electric material, or listen to a broad scope of eras and artists depending on your mood, SourcePoint 8 plays it all without prejudice. This is a speaker that conveys recordings in ways that will touch your heart and stir your soul.
Designed and tested in Jones' private studio, and configured around a custom-tooled eight-inch concentric driver and 1.25-inch soft-dome tweeter centered within the woofer cone, SourcePoint 8 retains nearly all of the technology, character, and structure of SourcePoint 10. As part of the speaker's point-source system, the cone acts as a waveguide for the tweeter to both match directivities and maximize the tweeter efficiency. It plays with exceptional control, tonal balance, and spot-on imaging. Working in synchronicity with the tweeter, the eight-inch paper-cone concentric driver keeps displacement to a minimum and helps deliver accurate midrange, taut low-end responsiveness, and powerful dynamics. Not to be overlooked: a brand-new corrugated surround that allows for improved linear excursion and minimizes diffraction corruption of the tweeter wave expansion.
Speaking of the tweeter: The "Twin Drive" magnet system for the tweeter and woofer are designed around high-energy neodymium magnets that, when combined, produce a linear low-distortion drive force, along with copper sleeves to reduce nonlinear inductance. Also inside: A two-way crossover with laminated-steel core inductors that provides smooth on- and off-axis responsiveness; Jones' crossover frequency and slopes seamlessly blend the woofer to the tweeter to further minimize the audibility of out-of-band anomalies.
Able to mate with a wide array of amplification sources and boasting a 47Hz-30kHz frequency range, SourcePoint 8 makes enjoying addictive high-end audio more pleasurable by removing barriers and hassles associated with the experience. No matter where it's placed, SourcePoint 8 can be dialed-in with ease to deliver maximum performance in any environment. Available without stands or with dedicated stands custom-designed to optimize the speakers' placement and stability, it can be displayed with or without supplied removable grilles.
At 80% the size of SourcePoint 10, the gorgeous cabinet on SourcePoint 8 features 3/4-inch-thick real-wood veneer panels, extensive internal bracing, and a sculpted 1.5-inch-thick front baffle. They help underline several defining themes of the 27.9-pound speaker: extremely low distortion, consistent linearity, and deep bass output that help convey music in a manner that blends the detail, specificity, and cleanliness of a traditional bookshelf model with the meatiness, liveliness, and range of a tower. Also doing heavy lifting: Two large rear-firing vents that permit high bass output with low turbulence. And, the sculpted swept-back facets of the front baffle reduce diffraction response errors typically encountered in conventional flat-baffle speakers.
With SourcePoint 8, Jones again carries on the company's mission to create first-rate components that honor Mobile Fidelity's studio heritage and help form a complete source-to-output chain wedded to the prized concepts of signal purity, faithfulness, and precision.
Specifications:
Frequency Response: 47Hz-30kHz
Nominal Impedance: 8 Ohms, 6.4 Ohms minimum
Sensitivity: 87dB/2.83V/1m
Crossover Frequency: 1.6kHz
Minimum Recommended Power: 30W
Max Power Input: 150W
Dimensions (WHD): 11.4" x 18" x 13.2"
Weight: 27.9 lbs.
