MoFi SourcePoint 888 Speakers
Nikhil
Moderator
Staff member
Hyderabad
Link: https://www.mofielectronics.com/pro...s-sourcepoint-888-floorstanding-speakers-pair
SPECS & FEATURES​
SPECIFICATIONS​
Frequency Range:
32Hz-30kHz
Nominal Impedance:
6 Ohms, 4.5 Ohms minimum
Sensitivity:
87dB/2.83V/1m
Crossover Frequency:
130, 1.6kHz
Max Power Input:
200W
Tweeter:
1.25" wide roll soft dome
Midrange:
8” Paper Cone
Woofer:
2 x 8" Paper Cone
System Configuration:
3-way vented box, concentric driver
Cabinet Finish:
Satin black painted baffle / satin real wood Walnut or Black Ash veneer
Dimensions (H x W x D):
Without Grill:
1070 x 320 x 410mm
42.13” x 12.6” x 16.14”
With Grill:
1070 x 320 x 425mm
42.13” x 12.6” x 16.73”
Weight:
96.2 lbs / 43 kg
FEATURES​
• 3-way vented box system with a concentric driver configuration for superior sound dispersion.
• Equipped with a 1.25" wide roll soft dome tweeter and dual 8" paper cone woofers for detailed highs and powerful bass.
• Available in elegant Satin Walnut or Black Ash real wood veneer finishes.
• High-quality crossover design for seamless frequency integration.
• Sturdy construction and sophisticated design to complement any interior.
I saw a few videos about these recently.
Interesting to note how much changes needed to happen to gain a frequency response of about 10 hz in the lower regions from the sourcepoint 10!! 2 more drivers and a massive cabinet and an intricately re-designed crossover. I am sure it will play at a greater scale too. Usually many brands just stick another driver at the bottom in a tower and chose a crossover point and be done with it! One of the reasons why many floorstanders sound worse than its bookshelf brother.
Th decision to stay with an 8 inch midrange unit to leverage the benefits of a smaller cone is interesting too.
