How much is a KEF Q300 locally? A friend of mine is contemplating the audio journey
A new Bakraaaa ... Muhawhahahaha! hyeah: hyeah:hyeah: Gobble Khush Hua ...!
--G0bble
Check with Saif @ uniquesys. PM'd you his number.
--G0bble
Prices were to increase after Diwali(profx told us) of Kef Q300.Earlier price 32K.
I tried Wharf 9.5, 9.2 and Tannoy V4 and its corresponding BS today with my Onkyo 609. Yes, I know! I didn't try BSs with similar price range as FS; planning to do that quite soon . Will keep you folks informed on that too..
Now, in 5.1 home theater mode, Wharfs were Ok. But in Stereo mode, AV and speakers didn't just go well. Its hard for me to explain; bottom line is I didn't find it quite natural sounding. The songs that I listen always sounded a little different!
Tannoys T4s were good; probably since I tried it immediately after Wharfs. It sounded more natural. The only thing that I didn't like was that it was a little boomy / a little too much bass at the cost of high freq. For now, I played it all in DIRECT mode. Guess this can be adjusted by playing with the equalizers. Not sure if this observation is right.
5.1 Home theater mode was good too with Velodyne Impact 10 sub. Guess better than Wharf combi..
Tried some Floyd, Metallica, Eagles and some India fusion and classical (same songs) for both auditions at same volume and AV settings in direct mode.
Need to try MA M4 in the same setting now. What do you think about KEF C series. Guess that is in the same price range. Also, Paradigm monitor and Polk suggested by Kittu and Flash above. Thanks guys!
Keep you folks updated. Please continue to share your thoughts.
. Yes, at low volumes, it didn't sound that good. Practicaly one play music at relatively low volumes and hence it does matter. Even at high volumes there was some thing missing!Wharfy's 9 series are power hungry speakers and come into their element at higher volumes or when mated with powerful amps . They sound recessed at lower volumes.
I own the Wharf 9.6 amongst other speakers and that has been my obervation.
Don't think the Tannoy's were new out of the box. It was placed around 2 feets from the wall; but yes those were jammed between other 2 FSs. I agree on equalizers. Thats why I didn't try eq settings yet.Were the Tannoy's u audtioned new out of the box . If yes then speakers need some time to break in to start sounding good and come into their element. If it did sound a little boomy , could have been a result of room placement or the speaker itself .
Ideally a speaker should sound good to your ears without you tweaking the Tone eq.
Fiddling with the tone eq is just moving u away from what the recording artist originally recorded.
I doubt the Tannoy's are boomy, Spiro can def help you a lending hand with this aspect.
Hopefully others in the forum could suggest on KEF and others.. Thanks!I cant comment on the KEF C series never heard them personally. I guess there are others who can help
The velodyne Impact 10/12 is a very well liked sub in this forum for people on a budget.
I find them pretty good for the price in India
I can comment, to an extent, on the Q-series from KEF. I have heard the Q500 and liked them. Maybe not enough to buy them over Paradigm's Monitor series but they did well. They are slightly forward sounding but certainly not bright. They are bass heavy so the liking is relative. And damn, they look chic
I wanted to check out Q300, just for the heck of it, considering the rave reviews this BS has garnered. Unfortunately, have not been able to do so till now. Q100 is the cheaper BS cousin of Q300 and I have read it is no match to Q300's capability.
Assuming the budget is <50k, it does not make sense to speak of Q700 or Q900.
I have not heard a lot about the C-series so maybe that is an indication of their "desirability" amongst the AV folks? Ofcourse, awareness is not necessarily the right parameter for judging the quality of a speaker. But what I do know is that in the avsforum, it is the new Q series which is talked about the most and rarely is the C series ever discussed.
Yes Wharfys and Onkyo's don't go well together, They mate better with Denon's.
Another Note Onkyo AVR's are not very muscial, Denon's do a much better job at music.
I own the Wharf 9.6 amongst other speakers and that has been my obervation. there are other members who have reviewed them and have the same feeling.
I am pretty sure you may have felt that there were certain frequencies missing during your audition. it could be a direct result of the 9.5 needing more juice flowing through its veins
I totally disagree. It might be your opinion or perception. But that's not right. basic thumb rule is, your ear is the best judge and no oneelse can beat it. I agree you need some powerful amp to drive Wharf9.6 for which Onkyo 609 is quite sufficient.
I have Onkyo 609 with Wharf 9.6 as front. Its good for both movie and music(stereo mode).
My wharf 9.6 does sound good at even low volumes, you have to really play with the settings (Eq,night mode and Dy-vol). I prefer using dual SUBs with my Onkyo 609, since I have only one SUB, I'm temp using my wharfs.
I have auditioned Yamaha671 with Onkyo 609 side by side and I have no regrets in choosing 609. The OSD in 609 stood ahead of yammy671. Also the xx09 series of onkyo is much refined from its predecessors.
I have auditioned tannoy with Wharf. After weeding tannoy out, I compared b/w Wharf9.5 & 9.6, then 9.6 is the winner. tannoy is good at handling vocal(HFs).
Again, the above points may be my perceptions.
Thanks for your inputs 007india. On your comment "really play with the settings" - I am running it with default settings, except that the IntelliVolume was increased from 0db to 6db. All other settings were same for both Wharf 9.5 and Tannoy M V4. I played the same songs and some how felt Tannoys were better. Btw, I didn't try 9.6s.I totally disagree. It might be your opinion or perception. But that's not right. basic thumb rule is, your ear is the best judge and no oneelse can beat it. I agree you need some powerful amp to drive Wharf9.6 for which Onkyo 609 is quite sufficient.
Well we each have our own perspective.
I was a little surprised when motorhead said that the Wharf 9.5 did not sound natural . I have the 9.6 and some other loudspeakers.
I did a direct camparo of Wharfedale 9.6 with a Denon 2106 and an Onkyo 809( not 609) at my house over 2 weekends
Yes both can drive the 9.6 easily. However with a high current amp. It does bring out a lot of detail which is otherwise missing at lower volumes
Pictured below is the B&W 685 perched on top of Pioneer CS303 (vintage) during the test runs connected to the Onkyo 809 . on the far left Wharfedale 9.6 disconnected though because was testing the B&W's on the right on the floor Denon
Had another forum member dwayne as well we ran through different speakers using both the AVR's to determine which was better for music as well as Video.
We both concluded that the Wharfedale's sounded overall better with the Denon for music. Infact with the other loudspeakers connected as well we had the same view.
Yes it could be our perception after approx 4 days of back to back auditions spread over 2 weeks in a real life house situation and not a couple of hours at a AV shop
We also paired the Wharfedale with a Emotiva XPA2 power amp for a short while and we immediately found a difference at lower volumes
But yes as you rightly said ""Let your ears be the best judge"" and thats why what sounds good to me may not sound good to you
I am not saying that the Onkyo is bad for Stereo. I am citing a general view that Denon's are better for music while Onkyo's are better at Movies.
I have not done a comparo with a 609 however considering the 809 is a the bigger brother of the 609 from the same series I guess our perceived notion holds good to an extent.
Mating Speakers with Amps is another important aspect as well. Tannoys mate well with Onkyo's as Spiro/ thecoolest one etc determined at an audition a couple of months ago. The same was noticed at the Pune HIfi meet with ruenigma's Paradigm titans. When mated to a Norge 1000 it sounded a tad bright and did not mate well . However it sounded fantastic with Sonosphere's NAD.
Here is a link to another review of the 9.6 by another forum member who after auditioning the 9.6 was also under the same view of Wharfedale 9.6 at lower volumes
http://www.hifivision.com/speakers/13396-wharfedale-diamond-9-6-review.html
PS : i am by now way saying you are wrong in any way. I am just putting forth my opinion
Started with Monitor Audio M4 this weekend and I liked it; found it balanced and natural. Good thing was that I didn't find that extra boom / bass that I felt a little with Mercury V4s. Now based on the comments above on Tannoys from some of you, I will have to try V4s once more. Certainly these 2 are options as of now. Movie experience with the MA M series was good; not out of the world!. But again, spent only limited time on that as I wanted to finalize the Front speakers first.
Then I went ahead and checked KEF C Series (C7 as they didn't have C5 for audition for now; probably I can try C5 next week). I tried Polk Audio TSi 400 along with C7. Tried these 2 back to back for each song. Both were much louder compared to MA M4 at the same volume (-20db). I had to move it down to -24 and -26dbs.
Some how, it was a little tiring after 3-4 songs. Probably it was Polk's impact!. I just couldn't enjoy at medium to high volumes - it was really hitting me; at low volumes it was sort of ok (-28 db +). Then tried a few more songs in KEF C7 and movies with its 5.1 package. Movie experience was good. Again it was a short audition.
Polk TSi is cheaper by around 25% compared to all other 3 (Wharf, Tannoy, Monitor Audio), which were more of less the same price (+ or - 5k for 5.1 setup).
PS - I am not able to explain clearly (aka technically) on why I like or dislike. Hopefully, I will learn that soon . But I have been trying songs that I have heard a lot lot times before and that way I could find whether I been liking it or not.. Need to learn how to explain that
Btw, no luck on Norge or Sonodyne dealers in Blr yet. Appreciate any help..
Sonodyne - go to their website and send them a query they will respond with dealers in Bangalore. They are pretty prompt at replying.
Later we tried Klipsch SW350 (8") along with Q acquistics book shelves (2020 and 2010) and we felt SW 350 was better compared to Impact 10.
Modern World in Old airport world (Domlur on the way to Richmond). Btw, what is your take between SW 350 and Impact 10?Where did you audition this combo? SW350 in particular?
Thou there are rave reviews on AVSforum and other places that Impact would put klipsch to shame, I found it reverse. Velodyne entry levels are not that great , starting with CHT and DD are the killers in velodyne. On the other hand many have reported amp quality issues on Klipsch well as long as you have 2 years warranty I guess you are good with Klipsch SW350/450. I am not looking for these any more as I realized I need a front ported ,front firing sub. More like SW110 and Velodyne CHT10 or 12.... If you find any deal across your auditions let me know.
