Hi Friends,
It’s been quite a time I have been off the forum; I mean, I have not uploaded any of new projects in recent time, I was too lazy to document it, I guess. I didn’t even bother to take some good photos during the built journey of this project.
This Project is an MTM completely designed & executed by ME, right from Enclosure design to crossover design. It’s a Mid Budget Project costing not more than INR 25K. Cost may increase if one goes for Premium Components for X Overs, Binding Post & of Course exterior finish of enclosure. The drivers used are I guess OEM for SONY may be this is what I was informed about the drivers. There were no TSP available so I had to measure them with DATS, once I got the TSP, the modelling was done in WINISD.
Project Cost.
Mid Bass Drivers: Rs. 4,000/- (4 Nos) – Including Transport
Tweeters ND28F-6 - 1-1/8" Soft Dome: Rs. 4,000/- (Pair) – Including GST and Courier
Enclosure Material with CNC cutting: Rs. 3,500/- (17 mm MDF)
X Over: Rs. 3,200/- Approx.
Connectors (MX Brand): Rs. 260/- (Pair)
Paint: Rs. 3,000/- for our job (May Increase or decrease, depends on how far one is willing to spend on aesthetics)
Damping (Sofa Foam): Rs. 500/-
Another 1000/- for Glue, Grill Guides, Mounting Hardware, etc.
Labor: 5000/-
Grill Cloth: Left over from earlier Project.
The Enclosure is 25 Ltr tuned to 55hz, the in room response measured is from 45hz to 20kHz. The Bass from such small drivers was amazing, I mean no one can actually believe the Bass was coming from the two 6.5-inch mid-bass drivers. This kind of bass I had heard was from Morel drivers, Very tight and punchy. I tested these speakers in open area, to my surprise the bass was well enough to fill the area, this was something I would say you rarely get from home audio speakers. Further to keep the things simple the cross over is also a first order crossover, The crossover point is 1.9kHz, Sound wise these speakers had a very tight and punchy bass (on spot punch), there was a little compromise in highs section as the highs were on a lower budget side, This can be overcome by using a good tweeter, may be SB acoustics "SB29RDAC" would be the perfect match for this speakers, But again the Budget would have gone up by another 7k. For Now I would say these speakers can give a tough competition to many Hi End Speakers within a Price tag of 50 to 60k.
Now sharing some Photos of built journey.
A Tea Break---
Back To Work Now.
The Drivers are mounted and are ready for taking measurements to create FRD and ZMA files. The tweeter seen in the below photo is a car tweeter, later it was changed and all measurements were done again with dayton tweeter. I do not have the photo with dayton tweeter so for a reference purpose this photo will work.
Getting the measurements. many of you point out regarding the reflections caused by walls, to overcome this i have done gated response and generated FRD files.
Final Outcome
A recorded video for reference
MTM - Test Track
Hope you all will enjoy the video and the built journey as well.
Project Cost.
Labor: 5000/-
A Tea Break---
Back To Work Now.
Final Outcome
MTM - Test Track
