Musical Fidelity Nu Vista 600.2 Amplifier
Nikhil
Moderator
Staff member
Hyderabad
Stellar review on the new MF Nu Vista 600.2 Integrated Amplifier from Tarun (A British Audiophile).
Link: Musical Fidelity Nu Vista 600.2
Nu-Vista 600.2 - Specifications​
Output​
  • Power: 160W into 8 ohms, 300W into 4 ohms, 500W peaks into 2 ohms
  • Voltage: 36 Volts RMS, 20Hz to 20 kHz; onset of clipping, 147 Volts peak to peak
  • Current: 50 Amps peak to peak
  • Damping factor: 100
  • Output devices: 2 pairs per channel
  • Gain: Preamp 4.3x (12.6dB) at maximum volume, Power Amp 34x (31dB)
Line input​
  • THD+N: < 0.005 % typical, 20Hz to 20 kHz
  • SNR: > 107dB ‘A’-weighted
  • Input impedance: 100 k Ohms
  • Frequency response: + 0, –0.1dB, 10Hz to 30 kHz
Connections​
  • Line level inputs: 4 pairs line level RCA connectors; 2 pairs line level balanced XLR connectors
  • Line level outputs: 1 pair line level RCA connectors, constant level LINE outputs; 1 pair line level RCA connectors, PREAMP outputs for e.g. biamping; 1 pair line level XLR connectors, PREAMP outputs for e.g. biamping
  • Speaker outputs: 2 pairs 4mm banana plug/binding posts
Power requirement​
  • Mains voltages: 115/230VAC 50/60Hz (factory pre-set); 100VAC 50/60Hz (alternative)
  • Consumption: <0.5W in standby mode (orange LED lit); 75W on and idle (blue LED lit); 600 Watts maximum
General Information​
  • Dimensions (WxHxD): 483 x 187 x 510 mm
  • Weight: 36 kg net / 44.3 kg boxed
