This is my first TT setup. I didn't want to spend much. I am not an audiophile, so my expectation was less. But I am very happy with the results.
TT - Audio Technica AT LP-60 bought from US 110v version.
Amplifier - Lepai LP2020A+ 2013 version.
Speakers - Hari Iyer's Krypton bookshelf.
I use a cheap 220v to 110v converter with the TT. It works fine. No problem.
I ditched the stock power adapter from Lepai and replaced with a 12v 4A adapter. Definitely there was a improvement in sound. I keep the volume slightly below the half way point. That itself fills the whole room. The blue LED is annoying though.
Krypton speakers are the best value for money speakers. Before buying I listened to Polk bookshelfs and inquired the price (16K at ProFx). I feel that Krypton sounds better than Polk for a lesser price.
Only thing I can complain now is about non availability of good LPs and about cleaning the old LPs. Somehow I am not able to get rid of the surface noise.
Planning to try Kuruvila sir's distilled water+isopropyl alcohol cleaning method (without vacuuming) . I will post the results.
