Hey Am sorry too was bit pre-occupied with stuff so only couldn't reply to the earlier post !
i worked with making enclosed transmission lines (in which the loudspeaker enclosure contains the back of the transducer, the transmission line, the stuffing and the transmission opening) and found that the sound was too bass heavy and "rich". the sound did not have the "immediacy" that I wanted, you know the feeling that either "you are there" or at least "the performer is here" kind of thing.
Well the basic transmission line theory itself is to make the bass response extended well below the Fs of the driver
!! so no matter what you do the sound will have a TL character ! but thats not bad ! coz if done properly it can give sub a run for its money in any stereo setup
! But this is again a very very subjective matter
! so will leave it at that ! Just like to add one thing here
(please don't mind
) but the normal TL or TWQT done properly can have a mids to die for ! have heard some and can only appreciate the sound ( I don't have golden ears but have to manage) ! so perhaps when I hear your set-up I can get the feel how what your tastes are (coz I have rarely seen very very few who have similar views on the TL design as you ) !
the surface area of the end of the transmission line opening being one fourth of the radiating surface of the driver.
On the above theory,Well its not at all the regular way of doing ! coz in any and almost all TL designs,the Mouth (or opening or end of the TL) area will be either double (some times triple ) or atleast the same as Sd of the driver ! so this is new to me and makes it a must see
As with the other projects of yours,just loved the pics so will surely like to see them one day
Now coming to the latest post, Ohh ok so what you wanted was to buy a Mic+Pre+Software ! Hmm the said 26K is bit on the higher side but if its worth then we can give it a try !
Having said that I"ll tell you this,The soundeasy (The soundeasy I suggested with the link to the Asawaari project where its used ) will do the job just fine with the basic stuff as they have covered all the inefficiencies of the regular (non Reference grade) components we may use in the setup ! The manual also very clearly stats that you do not need a Reference grade amp to output the Signal Sweep ! and also some decent quality Mic will do ! so if we go this way the cost could be hardly 2K (not including the software as it costs 250$ and is a single user license,so no sharing possible :indifferent14: ) ! I have studied that soft and is very very good and be used reliably !
Also there is an Indian company called AudioLec in Pune who have customised solution for this ! it includes hardware and software package ! they say its used all over including the some TOP rated Indian Speaker Brands ! but the only issue is the cost :sad:! as its priced at 70K !
Anyway thats what I think bout the thing ! Hope you don't me being very straight (coz thats how Iam ) ! please don't take anything in the negative or the wrong way !! I wrote what I felt like !
Regards.
