My first basic audiophile stereo setup Topping T20 + Cambridge Audio 30
hope you are playing flac or equivalent..
nice simple rig.. enjoy the sound..
look out for a nice usb dac ( not too expensive ) or better if you can get a loaner from someone for a few days to try.
but if you are enjoying it..as it is.. just leave it alone..
mpw
@mpw, yes. All my music has moved to FLAC / 320s. I'm not convinced about a DAC, will definitely loan / audition one before I add it to the setup.
Hi. Was just trying it out. Any other music player that you would recommend?
Just use foobar normally. WASAPI generally works better for digital output. That is if you are sending the output to a DAC.
If you are using the 3.5 mm output of your soundcard and sending it to the amp, foobar should do the job (wihout WASAPII).
Try it and see if you see any audible difference of sound quality.
