Whoa Reuben, Congratulations; lucky you. Sorry for the noob question but where is the tonearm and cartridge?
After RP's and Shafic's knighthood, I can't hold back the excitement and have both some good news and bad news for you all.
First to the bad news: My Lenco Master turntable build is put on hold indefinitely. Not sure when I will resume work on it, maybe after a couple of months or a bit longer.
Now to the exciting news: YES!!! YES!!! YES!!! (as Daniel Brian would say), I too have been knighted. Sir Garrard 401 is also making his way to my home. The deck is sitting happily at my friend's place in London and will be hand-carried down, next month. It is from an audiophile, who had it for many many years (from new). Here are all the pictures that my friend sent me after receiving the deck (wanted to hold back disclosure till the deck arrived, however, its raining Garrard 401s on our forum, so why not get a bit wet in the rain). Here are the pics:
A very special THANK YOU, to Sir RP for his honest and intricate guidance, without which, this adventure and achievement would not have been possible.
It was about time!
My hearty congratulations to you Sir Reuben. A very fine acquisition indeed. Motor looks in top notch condition and I am sure we will all love this British legend. This also makes the build up project so collaborative now.
Wait, I see something unique. Not sure if you noticed this, but this piece is an early 401 which has the Flat Strobe which is said to be quite rare.
I am delighted that I could be of some help to you. Your help to me from the very beginning has been invaluable.
Cheers to you from all us. We both have our builds to come so let's get to it...
Wow! Pretty amazing - the table is in spectacular condition. What arm and cartridge are you planning to add to the table? The plinth build will also be crucial.
Congratulations Reuben. The player looks in real mint condition. Amazing acquisition. And truly, its raining 401s on our forum. The TT Gods must be happy and are showing their grace on our forum members and helping them acquire what they have been looking for long.
When is Sir Garrard coming home?
Sir Reuben!! Congrats!!
The deck looks awesome. Helping people is a great feeling. BTW how come there is no plinth and arm?
Yes indeed, on another note Saket, people like myself have a lot of experience with good turntables like Technics Direct drives and can talk for hours about them. However at the end of the day, these TTs are not in the same league as the big ones and we've never played in the big league. Shafic, Record Player and my accquisition of the 401 is great for the forum as we too can add to the already knowledgeable crowd on the Thorens', EMTs, Garrards and Sondeks.
On another note, the 401 also realizes my dad's dream. He always wanted to get one of the big Garrards but being a Central Govt. Engineer, he could afford only a TT like the Garrard SP25 (which he bought during one of his foreign visits back in the 70s). Unfortunately he is not around to see Sir Garrard make his entry.
The gentleman who owned it had a single plinth and SME3009 and used to switch between 2 401 decks, using the same plinth and tonearm. He was gracious enough to let me choose which deck I wanted and I opted for this one. It would have been difficult for my colleague to carry the plinth anyways, so in a way, getting the deck without the plinth was a blessing in disguise.
when choosing a material for plinth duty, there are three main parameters to consider, stiffness, mass and damping. Of these three, damping is the most important, as it is the hardest criterion to satisfy (enough damping!) but also it has effects right across the audio spectrum (and above!). So choosing a material starts by looking at that material's damping factor. A damping factor of 0.4 or above is the target to aim for, but 0.4 is good enough for our purposes. Stiffness values are considered, more from a structural point of view, and more stiffness can be added using thin metal plate, for example.
Mass is a product of size and density, but a low density, stiff and highly damping material would make a suitable plinth, as much as a high mass equivalent. And don't underestimate the importance of the thickness of the material. Thickness means the vertical component if a panel is laid flat on the ground. So density, per se, is not important.
One cannot guess (or calculate) the damping factor value (I've tried to guess, and I am usually wrong! ), the only way is to test it. If you want it tested (for free) you will have to send me a piece, 100mm x 100mm x about 20mm
As regards vibrations and resonances, these terms are often confused, and used interchangeably, incorrectly. When it comes to plinths, we could have vibrations, some of which may be resonances. A resonance is a natural vibration where maximum amplitude is reached with a minimum of energy input. Pick up an object, and hit it, it will usually make a sound, these are the resonances. However, we could have a vibration source (like a motor) and place it on a panel of wood, and sense the vibrations in the wood. These are vibrations, and not resonances. Only if the forcing vibrations from the motor were at the same frequency as the natural resonance frequency of the wood would we have resonances, (and a big problem)!
The plinth is there to support the turntable mechanicals, but more importantly (in my opinion) to reduce the amplitude of vibrations from the turntable, floor and air which could vibrate the whole system. To reduce the amplitude of the vibrations from the turntable, it must be connected to the chosen plinth material as well as possible, so-called 'coupled'. This is because the plinth vibrates (mostly) by moving up and down. The goal is to couple the turntable bits to the plinth material, so that they move up and down together. That way, the chosen material, if it has a good damping factor, will reduce the amplitude of the vibrations very quickly, so that they don't have time to build. This is where most plinths fail, the chosen material/s do not disperse the energy in the system fast enough, and the vibrational amplitudes build to unacceptable levels.
cld found its way into hifi by the term being misapplied, as mentioned. It has been used in the aircraft industry for a long time, where vibrating panels have been damped using this technique. It is most effective where the thing to be damped is a thin panel. I would not make a plinth by sandwiching a viscoelastic layer between two pieces of wood, in that case, it is wrong to support the lower layer while connecting the turntable to the upper layer, as the viscoelastic layer will de-couple the lower layer.
I have been considering plinths as a flat panel, but some plinths are more of a picture frame construction. In that case, each side can be though of as a panel, where the thickness is considered the smallest dimension. The stock Lenco plinth is like this. In which case, each part of the frame can be considered for vibrational analysis, but that requires software called 'finite element analysis', which is expensive, and I don't have.
