My marantz sr5008 often going into protection mode
The impedance of the speakers sometimes depends on the freq its predominantly playing.
The worst offenders are the ribbon tweeters - planar magnetic type like used by infinity or carver. If you had something with that, and its playing a guitar solo, you're basically only using the tweeter and it will easily drift to under 1 ohm and present a capacitor like load to the amplifier.
I have a denon 1610 and a marantz 5002 (the closest to the 2 you have) I like the 5002 a lot more but I never had any of these run that high volume nor have I got any real drifter speakers.
There are also speakers that present like a inductance to the amp though those typically drift a lot less - like not much below 2-3 ohm for an 8 ohm speaker.
I suspect your denon is more efficient than the 5008, hence it wasn't drawing as much from the stabilizer. So your issue may be with the stabilizer ??? I am just guessing. When its over heating, see what component reacts best to a cold air blast. You also have to be careful - hit the heat sink, not the component directly, you can split it by cooling it too fast.
Cool.
Srinath.
Cool.
Srinath.
On the volume knob 0 to 98db what are your listening levels?
Mine on denon I listen at 68to 70 and
On marantz 60 to 65
I believe somewhere around 45-50. I have not used them in a while. I also live in a very quiet area in a well insulated house (else I'll freeze to death) so even a little volume goes a long way. Also I have pretty high spl speakers. Over 92 db is good, for that usually. I'll probably setup the 1910 in my bedroom in a bit. I'll look into it some more then.
Cool.
Srinath.
Guys at marantz service centre, Mz audio,mumbai are not taking my call. Tried several times. don't know what to do
Got my AVR back after 1month. As per service people BOARD is changed.
Now the problem is through USB the sound is too low that even I am raising to Max hardly I hear any thing
This is also running very hot
Probably all marantz avr are running very hot due to descrete amps
