That's one interesting setup. Looks like you have been in the game for a while ! Will you share some pics ?Hello there
I’m a new members
here is set up
Lowther Ex2 with maouhorn enclosure
300B singleended Amp
Transrotor turntable ref TMD80
New member
Yes but long time about 17 years.That's one interesting setup. Looks like you have been in the game for a while ! Will you share some pics ?
thanksWelcome to the forum
Thank youWelcome Mr. Nayar. Happy Listening...
Since it is a custom lowther build I reckon some help from the Rethm manufacturer in Cochin ?Yes but long time about 17 years.
I’ll share
thanks
I have never met Rethm guy yet. I knew aboutSince it is a custom lowther build I reckon some help from the Rethm manufacturer in Cochin ?
I’ll find out.. Since I have shifted to small room houseSince it is a custom lowther build I reckon some help from the Rethm manufacturer in Cochin ?
I need to raise my pic. It says too largeThat's one interesting setup. Looks like you have been in the game for a while ! Will you share some pics ?
Spelling mistakeI need to raise my pic. It says too large
very interesting placement of speakers. . Does having them adjacent to the side walls not affect the sound?
These are designed to place close to the wall so that you get extensive bass response. I have been using them since 2008 never looked for any other speakers for my set up.very interesting placement of speakers. . Does having them adjacent to the side walls not affect the sound?
I presume the speakers must have a rather wide dispersion since you've not toed in the speakers.
Yes. I have made my first Lowther fidelity enclosure in 2007 But it was failure. I was not matured enough to understand the horn design and the kind of wool or MDF that should be used for construction. It was lacking a bass but very nice mid. The problem was an MDF selection.That a serious TT ! Interested to know more about your Lowther horn design. Any references or links on the design ? Thanks.
I’m now planning to sell this enclosureThanks
ThanksThis was not a Lowther design and it was developed by a Germany designer Andrew Mahou. I do have contact with him via postal
Letter only or fax. He doesn’t use internet or mobile that is what he said to me few years ago.
Now he must be using iPhone I’m sure .
if you buy new drivers then they provide you a free plan blue print.
View attachment 57348View attachment 57349
Hello there
I’m share my Transrotor reference TT photo.
it has two tone arm. Two motor.
you may like it. Model no Transrotor Fatbob TMD 80
Magnetic bearing
No tumble noise no floor noise like garrard 301&401. Sounds extremely wonderfulSME 12” tone arm and Rega RB 800
weighting 42kg +accessories
100% precision made machine.
View attachment 57363View attachment 57365
Hello there
Magnetic bearing
Thanksawesome ! love it.
ThanksVery nice
