Need a sub for Q Acoustics M20 wireless
ok how does the action movies like mad max will sound in this ; do u get the infrasonic sub effects where u feel the sound but don’t hear it
This goes down to only 24 hz at -6db. You will not feel the infrasonic bass. I haven't watched Mad Max, but the opening sequence of Edge kf tomorrow plays fine.
Why don't you take a demo of bith and decide?
There are two types of bass, tight controlled and bass with extention. You need to decide your taste. REL will never have the extention that you desire.
I recently bought a new pair of M20 powered speakers and I want to get as much clean, accurate, fast bass as possible with feel-able low extension upto at least 30-32 Hz as I normally listen to bass heavy music like riddim and will be occasionally watching movies. You can say 90% music + 10% movies. My room size is 10x12 sq. ft with a bed and a giant wooden almirah on the right. The speakers are placed 2-3 inches from the window behind them on table top. Planning to place a 10" sub underneath. My budget is 45k INR (540 USD) and max 50k (600 USD). Was eyeing at powered options like Klipsch 100SW which I'm getting at 41,300 INR rn from a local dealer in New Delhi. Also considering Bic F12 (might be overkill for my 120 sq ft., so pls tell me whether I should avoid it or not) and Q Acoustics 3060S 8" (ik both will perform very differently but I'm ready to sacrifice some of that oomph factor that I probably won't be getting from an 8 incher as long as I'm enjoying my music without distortion). The dealer also said that if I wait for a month he may or may not be able to arrange a second hand REL HT/1003 MKII and get it close to 50k but I scarcely believe that. An OLX user is selling an SVS SB2000 Pro in a custom-cabinet for 50k but I doubt it will perform even remotely close to original.
Is RSL Speedwoofer 10E available in India?
Or should I save some bucks and get a PSW10 for 26k lol?
Request y'all to help me find a decent sub. What other options do I have under strictly 600 USD (preferably 10 incher)?
Hello, just curious what you eventually bought. I have the same set of speakers and I am also looking for a sub with the same budget.
