Need advice on buying an amp
Nad falls under little brighter side and you may happen to spend little more money for restoration.
You can check fully built class D amps as well.
What is your speaker model?
Badri M
It is an old Kenwood bookshelf speakers came with a deck system ..i only own the speakers ..model no i'll look up andbpost here by friday coz i'm away from home
It can handle 90w max power
It is a 3 way system..
With 8inch woofer
4inch mid and
3 inch tweeter
Freq range 42hz to 22khz
This is all i remember
Sent from my XT1706 using Tapatalk
