Hi Friends,
I'm planning to upgrade my current setup and was looking for some advice on the upgrade path -
Following is what I currently have
Yamaha RX-V450 receiver
JBL NSP2 speaker package (4 x N24 bookshelf, 1 N-Center)
SPACE Sub (powered 100W)
Samsung Smart TV - UA46ES7500 (I normally connect HDD with HD-movies + FLAC/MP3 music to the TV via USB)
Panasonic BD85 Blu-ray (not used much as I mostly watch movies from HDD connected to the TV. I do use it for FLAC/mp3 playback via USB as I don't need to keep the TV on)
Pioneer DVD Player DV366 (Not used much now).
Tata Sky+ HD
Interests: Both Movies and Music (would say 50:50). In Music, mostly Soft Rock, Pop, all kinds of Hindi Movie Songs, Hindi/Marathi Classical.
Would like to know what would give me most bang (in terms of audio enhancement/hearing pleasure) for the bucks -
- replacing the front two bookshelf speakers with floor standers
- Replacing the receiver with higher end model
- Or adding an integrated stereo amp in the mix - if that is possible (my receiver does not seem to have analog out which could have been fed to stereo amp - so not sure if this is at all possible)
Budget wise - I had allocated Rs ~30k for towers + ~30k for an amp upgrade. So I can say ~60k overall.
Would appreciate if you could advise me on what upgrade path I can take.
Thanks in advance!
- Pramod
Tata Sky+ HD
Thanks in advance!
- Pramod
