Hi Members,
I am setting up a home theatre system and need advice on matching speakers and sub for Denon AVR-X1800H, Some details about my requirement.
Budget: 1.2 lakhs (excluding the receiver)
Setup plan: Starting with 3.1 within this budget and planning to expand to surround setup later.
Note: Not planning a dedicated room or soundproofing at this point in time.
Some speakers I am considering from my study:
Q Acoustics 3020i+3090i
Mission QX2 + Mission QC (concerned about compatibility with X1800h as these speakers have 4-ohm impedance (8 ohm compatible ) while the receiver supports -6-8 ohm)
Sub:
Taga Harmony TSW 212 SE
Polk GTS 10/12
Yamaha NS Sw 100
BIC America F12
Few questions I have:
Are the Q Acoustics a good match for Denon 1800h?
Can the mission speakers be safely paired with 1800h given their impedance ratings?
Are there any other better recommendations in that budget range?
I am based in Bangalore, any good option to audition the recommended speakers locally?
Appreciate your help.. Thanks you!
Sub:
Polk GTS 10/12
Yamaha NS Sw 100
BIC America F12
