need buying adviseHOME THEATER IN A BOX
india
i wanna buy home theater in a box.
my budget 35k
my preference-50%movies,50%music
i have dragonfly usb DAC.
i wanna play well my flac collections.
my choice
1-onkyo 3500
2-yamaha 196
3-pioneer 071
pioneer got avmax 2012 best product award.
plz compare above 3 side by side
I'd second the previous suggestions from prosenjit and just4kix. I too was in the same dilemma as you are, after joining this forum and the valuable advice i got from the FMs here i've decided to scrap HTiB and build the dream system in a staggered manner. Good luck!
my budget 35k
my choice
1-onkyo 3500
2-yamaha 196
3-pioneer 071
You won't be able to enjoy FLAC in home theater in a box. They are not well suited for music.
Buy Marantz / Yamaha AVR and then add 2 bookshelf speakers like Wharfedale 121. You can later add other speakers. Its the best solution.
