sdhameshia
@elangoas: it gives option for either full screen or 4:3.
Hi sdhameshia/sanchits,
Please suggest me on this product.
40PHL5059
i went to showroom and stunned after seeing PQ of sony. But those are way too costly 60+ K.
do you suggest me to buy this product. ?
and another question. I was checking the price of this product in showrooms. same product costs 45k.
How flipkart and snapdeal is giving for 30k ? this is making me to think that "am I getting some local or second hand product or the one which has issues".
as of other reviews, i found that sound is not good. But i think i can manage with that. i can buy a home theater or an amplifier.
My requirement is 40 inch led tv with best quality.
some of my friends are saying that philips was good in crt tv,home appliances like grooming kit/lighting bulbs etc.
but sony, samsung, lg are best in LED. Is it so ?
you have any facts why you preferred philips.
also, i like that philips giving 3 yrs warranty.
Hi Sanchits,
I read your posts. But you have given your comments in too much technical term and i dont understand much
What if I don't find sweet spot after tweaking it ?
These lines from ur posts are making me to think a bit.
Though the reds n shades of reds are still quite pronounced even after tweaking.
But yes, for the money I think its a decent buy.
You did not say it is the best buy
a soap opera effect ,
there is a bit of ghosting in SD video
I think I'll get used to the popping reds with time, overall I am satisfied with the PQ.
What is red poppings ? Still you get such marks ?
doesn't have a great viewing angle -> should i bother abt this? how will this affect a normal user.
How is the performance of the TV now ?
In my area, i did not find this tv in local showrooms.
I live in chennai.
Hi sanchits,
I have the same model as well & I'm unable to find 1:1 pixel mapping feature; as I have WDTV Live the picture is slightly cut on both sides as it is slightly overscanned in the TV itself but there is no option to turn it off. Since you have connected a PS3 you too should face the same issue; have you found the option to disable it.
Hi sanchits,
Guys,
am planning to buy a Home Theater system. are you guys using any with this TV? I donno about connections options on this TV(Audio out).
BTW I sold my 40PFL5059 few days back going for VU 55".
Fellow users can access the factory settings menu by pressing the home key followed by 2580 in quick succession, which might be helpful in tweaking the PQ a little bit also for getting 1:1 pixel mapping
Thanks a ton . this is exactly what I needed. I has rgb gain settings as we'll as overscan settings.
I think I might be able adjust the reds n blacks maybe from here n improve the PQ.
Btw, why did u sell the Philips ?
Has anyone seen the "Banding", backlight uniformity problems on philips large screen tvs especially 40pfl5059? This can be seen if you view a plain white or gray photo in your TV (or a natural scenary with blue, gray or white clouds/sky).
http://www.avsforum.com/forum/166-lcd-flat-panel-displays/1456452-normal-bad-vertical-banding.html
The 40pfl5059 tv i have seen has both vertical and horizontal bands.
It seems like it is a common problem with edge-lit led tvs.
in showrooms, i noticed very little banding in tvs that costs more than 40k (jun 2015), but a lot better than 40pfl5059.
