skelfoutlaw
Hi Guys,
I am looking to buy a HDMI cable to connect my projector with the soundbar. The length I am looking for is minimum 40feet(12m). As its a 4k projector with HDR I need minimum 18gbps 2.0b compliant HDMI which can support 4k@60Hz HDR transmission.
Tried multiple copper HDMIs from Amazon but nothing seems to work properly. Finally thinking to go for AOC HDMI.
Kindly suggest if you guys are aware of any copper HDMIs which will work for my setup. If not, any good budget AOC HDMI options?
