Hi. I am trying to put together my first home theatre and am a little confused about what AVR to buy.
The setup will be in my living room which is roughly 16 feet x 14 feet. 16 feet concrete wall behind the Tv (extends further to a passageway). 16 feet concrete wall opposite the Tv. The back of the sofa is touching the wall. Right side of the room side is roughly 2 feet of pillars and 12 feet of glass window/door. The fourth side is 10 feet concrete wall and four feet open passageway. the open passageway will begin about 2-4 feet to the left of FL speaker. I have a 55" Samsung Crystal 4K Tv from 2020. No plans to upgrade the TV and no plans to add a projector as of now. I am mostly just looking to upgrade to better sound. I currently have a Samsung 5.1.2 soundbar.
I don't yet have any speakers but a friend has offered to give me a pair of KEF Q350's that he doesn't use anymore. I will initially run a 2.0 setup and starting looking for another Q350 or a Q650C for the centre and gradually upgrade to 5.x or 5.x.2. I'm not sure if i will be getting a sub or not. If the speakers provide enough bass then i might skip the sub.
I will be ordering the AVR from Ireland and have narrowed it down to these 3 based on my budget. The X2700H is 56000 brand new, SR6015 is 64000 brand new and SR5015 is 72000 open box.
Based on my research, SR5015 is the Marantz version of X2700H and the only major difference is that Marantz has pre-outs. Is that correct? if so, is it worth spending the extra 16000.
The SR6014 is supposedly a better amp has a better version of room correction but does not have HDMI 2.1. If i don't do any gaming, do i need HDMI 2.1?
Another option is Marantz NR1711 for about 60000 and i really like the small size but i am not sure if it will be enough power. On most forums, the majority opinion is to go for a full size AVR.
I'm leaning towards the SR6014 as it seems the best value to me. Will this be the best option out of these three?
All 3 come with standard warranty from an authorised offline dealer in Ireland. In case something goes wrong, it will be possible for me send it back for a warranty claim.
In India, i am getting a Denon 550BT for about 60000 and the Denon S760 for about 75-80000. The X1700H is about 100000 and out of my budget. Considering the savings, should i get it from overseas or is it better to have local warranty?
