Around 8000 rupees for the ASUS Xonar. The Auzentech is not available at my city.
Where do you get the Xonar D2X for 8k in India? I am paying 8500 to get it from US
![Big Grin :D :D](https://cdn.jsdelivr.net/joypixels/assets/8.0/png/unicode/64/1f600.png)
I have some doubt about setting couse even my desktop is not clear with hdmi but with vga it is good,
REGARDS
Where do you get the Xonar D2X for 8k in India? I am paying 8500 to get it from US![]()
I have seen this issue as well. The desktop looks really bad with HDMI. I can't say it's the cable, but both times I was using a cheap HDMI cable. But movies etc look better in HDMI than VGA. Do set the display settings for HDMI from the web (search for best settings for your lcd/plasma). I do have a second LCD with DVI input and I use an expensive DVI cable to connect it, and the picture is very very crisp through DVI.
My lcd dont have DVI input but if i connect lcd with dvi to vga is there chance improve video quality.
thevortex,thanx now my aptical cable connection is working fine.
REGARDS
Thanx bhaskie, now i have connected my lcd direct with hdmi but steel some not looks like high defination, i dont understand what i m doing wrong,and power dvd not supporting MKV format .
REGARDS
REGARDS
after long time i m back with my old issue ,i have tested my hdmi cables with samsung HD player (demo player from my friends samsung plaza) and this cable r working fine so i thing i need one good video card ,can any one suggest me a v. card for my Giga 780G motherboard some thing like this.
Three HDMI Graphics Cards Tested on LCD TV Sapphire X1600 PRO HDMI :: TweakTown
REGARDS
(ASK ME ANY THING ABOUT U R MOBILE PHONES 99% I CAN HELP YOU)
i have a query regarding the sound going to A/V receiver. Which would give the best performance from speakers?
The PC decoding the sound or the A/V receiver. My guess would be to send sound unprocessed to the receiver to achieve maximum performance, which has benefit in terms of saving extra bucks in purchasing good quality cards like XONAR.
Am I correct?
Also please advice how to pass unprocessed sound over HDMI. I am not sure whether my mobo(GA73PVMS2H) has SPDIF header or SPDIF out.
There is something like nVidia HDMI pure wave in my mobo(which has the capability to pass sound over HDMI), but I am unsure how to pass unprocessed sound..
I have a receiver which can process audio over HDMI...
wow didn't think it was that simple..
just to confirm.. i use zoom player, which allows to configure various filters to be configured for decoding sound, should i remove these..
also please provide an answer for..
Which would give the best performance from speakers..
The PC decoding the sound or the A/V receiver?
