Need help on selecting 42~46 inch TV.
bhvm
Opera House
Hello all!
I am looking forward to buy a new TV for my parents.
The TV shall be full function (USB input, PC imput, HDMI, Audio Out etc).
one of the toshiba models caught my eye-
LG 42 inches CS560 LCD Television - Buy Online @ Snapdeal.com
seems to satisfy me, but I can't seem to find any reviews on it.
Can you experts let me know if its worth that money?
Any comparable model around?
First look at picture quality than look features. A CCFL backlit LCD deliver worse PQ.
manish,
What could be wrong with this model? It supports Full HD 1080.
Also whats wrong with the CCFL backlight? I personally Find LCD TV better for eyes than LED TV. anyways whatever LED TVs we get are NOT TRUE AMOLED like Samsung and Nokia phones, they are just Edge LED lit rather than CCFL. I feel LED TVs have more glare even with brightness on low.
Specs are bit confusing of LG42CS560
Its an LCD TV
with CCFL Backlighting
but has Advanced IPS LED Panel
so its a LED LCD TV or just a LCD TV ??
Where did you read LED, Mr?
Model No : Toshiba 46PB20ZE LCD TV
Specifications :
Main
Product Type - LCD TV
Screen Type - 46
Aspect Ratio - 16:9
Dynamic Contrast Ratio - 48,000 : 1
Brightness (cd/m2) - 430
Resolution (H x V) - 1920 x 1080
Viewing Angles (Degrees) - 178
Panel Response Speed (ms) - 10
Visual
Video Engine - Power Meta Brain
Video processing - 10 bit
AutoClean - Yes
Auto Signal Booster - Yes
3D Colour Management - Yes
24p - Yes
Comb Filter - 3D Y/C (PAL & NTSC)
Intelligent Backllight Control - Yes
Mpeg Noise Reduction - Yes
Real Digital Picture - Yes
Picture Mode - AutoView / Dynamic / Standard / Mild / Movie / Eco mode 1 / Eco mode 2 / Game / PC
Audio
Stereo System - NICAM B/G, I, D/K, & German Stereo B/G, D/K
Speakers - (4.2 x 16cm) x 2
Audio Output - 10W x 2
Features
Media Playback - 28 Video Format / 4 Audio Format / 2 Picture Format
External Hard Disk Compatibility - Yes
AutoView - Yes
Teletext - Yes
Multilingual OSD - English / French / Russian / Simplified Chinese/ Thai / Malay / Vietnamese / Arabic/ Persian
Hotel Mode ** - Yes
Connection
Antenna Input - 1
EXT 1 - Input : Composite Video + Component + RCA Audio
EXT 2 - Input : Composite Video + RCA Audio (Side)
EXT 3 - Input : HDMI 1 (3.5mm Mini Jack, Common with PC Audio)
EXT 4 - Input : HDMI 2 (side)
PC Input - D-Sub 15 Pin + 3.5mm Mini Jack (Common with HDMI 1 Audio)
Output - Optical + 3.5mm Mini Jack Audio
Digital Input - USB (Side)
Signals
Receiving System - PAL I/ BG/ DK, SECAM BG/ DK, NTSC M/ BG 4.43
Colour System - PAL, SECAM, NTSC 3.58 / 4.43
Video Signal - 480i/480p (60Hz), 576i/576p (50Hz), 720p (50/60Hz), 1080i (50/60Hz), 1080p (24/50/60Hz) through HDMI
RGB Signal* - VGA, SVGA, XGA, WXGA, SXGA
General
Automatic Voltage Regulator - 110-240V 50/60Hz
Power Consumption (W) - 214
Dimensions (W x H x D)mm without Stand - 1108 x 713 x 77
Dimensions (W x H x D)mm with stand - 1108 x 772 x 241
Weight (Net) kg without stand - 17.3
Weight (Net) kg with stand - 18.5
Warranty - One Year Manufacturer Warranty.
anyways frosts, so what do you think about the TV... Thats the point. Price is near 50K
also will someone tell me if this is Glossy or Matt device?
Well you cant expect more from this TV since its price is cheaper than the AKAI 46 inch model (48k) . I would suggest you if you for 50k budget 40-42 inch you will get better products
Not always bigger is better
My budget is 70k max and I wanted to buy a 46 inch LED TV but most of the models I am not able to accommodate because of width constraint as where i will put my TV on one side there is main door and on other kitchen entrance .
Samsung 7 & 8 LED series models accommodate but its totally out of my budget.
My viewing distance is 12-13 ft
The only models i guess which can come looking all major factor would be only
Toshiba 46VL20
Toshiba 46TL20
Toshiba 46PX200
Toshiba 46PS20
I would be watching news channels a lot and also daily soaps so need good picture quality
Also would be watching movies with my 1TB HDD
No gaming
3D not required ( just an advantage ) wont be using once a month also
So which one to go for ??
choices
samsung plasma 38k--semi
panasonic plasma 37k--semi
panasonic plasma 47k---full+3d
all 42 inch range
panasonic 50 inch plasma semi---55k
or toshiba 40k 40 inch model...........
experiment those and check what is pleasing you.
persons who say lcds panels with ccfl backlight are of worst pq have not demoed them themselves..just has read somewhre and copy pasting the lines.I personally own sony lcd 40 inch...and find its pq better anytime than led panles..........
led panels are brightere anyway and looks real real fantastic for discovery/nat geo hd programmes..but very ugly looking for movies.the movies color palatte is lost somewhere in led panles.....
have anyone visited a quality multiplex who run a show with a color pallate like led panels........answer is no.so why choosing led for movies.anyway also demo led...if it pleases you go for it.for led try sony ex models.
and off course plasma are boss.no competetion with them except very very high end led panels.even there the movie touch is little missing.
