Need help to find a Subwoofer
ramvenk
Chennai
Need all your thoughts to find a best suiting subwoofer for my setup.
I have a Yamaha AVR rx479 with Wharfedale 220 fronts and centre and my old Aiwa speakers as rears. Now, I need to add a sub..
I have a tight budget of 20 - 25K.. Kindly suggest..
My hall is 12*18 and watch movies and music equally...
Thanks...
These are some models in that budget you can check
Polk psw-110 ( 18k)
Wharfedale sw150 ( Around 28k )
Thanks...
Will suggest in following sequence.... however been said that best audition & then take a call :)
1> Taga SW-10
2> Polk PSW110
3> Boston Acoustics ASW 250
4> Taga TSW-120/TSW90
5> Sonodyne Roarr
Binu AP
LG 42" Plasma | Marantz PM6005 | AJ FS52 | Velodyne Impact 10 | Panasonic dmp bdt220
Thanks a lot guys... will check out each of them.. Is there places where I can audition these ? the Polkss , the Wharfedales or the Sonodynes ??
Hi All,
Can someone help with comparing Wharfedale d10 subwoofer to the Polk 550 ? Apart from Remote and custom front / down firing, how is the performance of each ?
