Need help understanding SVS Subwoofers
ArNaV.
India
I am upgrading from a yamaha sw200 and have SVS PB 1000 pro in mind and have listened to it and am satisfied by it but after comparing the specs and price of SVS PB 1000 PRO AND SVS PB 2000 , PB2000 is cheaper and have better specs .
Why is it that a lower varient with ok specs (PB1000 PRO ) is more costly than compared to higher varient and with better specs (PB2000) is cheaper .
Can you check klipsch Rp1000 and 1200. Really great subs. 1400 also
Actually i have listened to svs and like it and will buy it but am unable yo understand why svs pb2000 is cheaper than pb1000 pro . If you can tell me it would be a great help thanks
SVS are awesome. I use an old PB1000 and love it. Just one thing different to others subs is that SVS perform great when you set them to a High gain setting using the knob at the back. So a near zero gain at source and a High gain on the subs gain knob gives best results.
MaSh
