Today I have placed order for - Marantz NR1710, Dali Oberon 5 (pair) and Dali Oberon Vokal.
I have not able to finalised the surround speakers and the subwoofer. I listened to Paradigm Cinema Sub which I liked a lot. It has a 8 inch driver which should be sufficient for my room. For surround I am planning to buy Dali Alteco C1. I really like it's design.
Looking forward to your thoughts and comments.
What is the cost of Dali Oberon on wall speakers?Dali Oberon 5 (Pair) - ₹ 67,000, Dali Oberon Vokal - ₹ 30,000 and Dali Alteco C1 (Pair) - ₹ 27,000
Yes, I tried Dali Oberon On-wall. It is indeed a great speaker. I really liked it. But I needed down firing height speakers for my surrounds so I went for Dali Alteco C1. If on-wall straight firing speakers fit to your requirement then I can surely recommend them.
MRP of Dali Oberon On-wall is ₹ 27,000 (per piece). You get around 10% discount on MRP for Dali speakers.What is the cost of Dali Oberon on wall speakers?
Dali alteco c1 will be right choice as all your speakers are dali.While installing C1 on your rear wall, do ensure that it is around 1 to 1.5 ft above your ear height in normal seating position, for optimum surround effects. After installing, you can play with the switch to see, which sound suits you best.
For 35k, you can check out Bic america f12 or many Polk audio subs. If you increase the budget, you can check out xtz subs, which is quite popular here in forum. Also check out Yamaha ns sw300.
Congratulations.. looks great, from where you have taken all this?
I bought Marantz 1710, Dali Oberon 5, Dali Oberon Vokal and Dali Alteco C1 from Auditro, Park Street. Yamaha NS SW300 from Yamaha store, Camac Street. Got really good deal from both.Congratulations.. looks great, from where you have taken all this?
Thanks. I have purchased Yamaha NS-SW300 sub. It sounds pretty good too.Congratulations Abhishek. Oberon's are very nice speakers. Add a subwoofer after some point in time.
