frank_dude_007
Hey,
So i am planning to build a home theater in mew house in the basement and i had some queries with which i need help
Firstly i will tell the specification of the area i have and what i have planned
The room in is 20x20 ft in size and will seat 6 people. 2 individual recliners in the front and a sofa for 4 in the back which will be elevated a feet.
and am planning to install a projector which can project 100-150 inch of picture
due to the size of the room i am confused between a 7.1 and a 5.1 speaker setup
I will mainly use it for watching movies and playing games and the occasional cricket matches and as a sound system so pretty much everything.
The main help i need is
Deciding on a decent projector (preferably with 3d support)
Home theater package with Amplifier (7.1 or 5.1)
I will use a PS3 as the disc player
Also should i use the wall as the screen or if i can buy a decent screen in the budget then please suggest
My total budget for all the equipment is around 1.5 lakh rs (little flexible)
Thanks in advance
Thanks in advance
