Just download madVR
Lav Codecs
Once you have installed both, setup media player classic to use lav splitter, lav video decoder and lav audio decoder as external filters. In lav video configuration, setup DXVA copyback as hardware decoder.
So what is the verdict here ? Does XBMC truly sucks in terms of PQ comapred to MPC + madVR ?or it is just mind tricks ?
CPU uses goes to 40-50% after using madvr(from 10%).
secondly why cant DXVA be seen when using madvr?So graphic card is not doing Hardware acceleration here?
Reading your posts i might want to try this and see for myself. I do have sufficient hardware and sources to make out the difference. I'll test it on my Core i3 HTPC connected to my Epson projector, projecting a 120" image. Now according to you guys it should make a difference, how big or small is the question.
I guess i'll have to see it for myself. Can you guys point me towards a basic tutorial to install all this and make is work ? I'll like to compare the following :
XBMC vs MPC+madVR vs quicksync setup
People who want a hassle free installation of codec packs with MPC-HC just see this site and download the file. I just downloaded and it infact installs the ffdshow, lav filters and also the latest mpc-hc player. Very nice indeed, you need to only install the madVR separately (if you require) that's it.
OK on my 42" Plasma, there is no visible difference at all. I ran MPC + Madvr (DXVA2 and Cuvid) and XBMC with DXVA2. MPC had 9-10% CPU usage vs XBMC only using 2-3 % . I've tested with 720p mkv, 1080p mkv and an actual Blu-ray as well.
I'll check it with my projector today. According to the suggestion it should make a difference, if not then i'm dumping MPC for good as XBMC interface is really what i would like to keep.
Many times,you dont need all codecs,so simply DL LAV filters & bitstream/LPCM over HDMI.
Yes that is correct, but you will realize that some codecs are missing only if you play a particular movie file. Also these does not occupy much space hardly 15 to 20MB so installing all at once makes sense.
thanks
LAV fiters has almost all current codecs which are used for movie ripping.
Oh,thats why new V.of any codec pack are launched.I have some avi movie files with Divx/Xvid codecs with mpeg2/mpeg3 audio which is not being played directly thru mpc-hc+lav filters. I had to install FFDSHOW filters for this codec alone and mark it as prefer in external filters and the movie is playing fine with madVR.
