Decadent_Spectre
Hello Nitin, a lot of what you are saying is basically what is on permanent repeat on AVS and I personally don't subscribe to it. I have experience with systems going to 10Hz and honestly feel that the frequencies below 20Hz are largely irrelevant having compared systems with and without a 20Hz HPF as well as using variable slopes from 6db/oct to 48db/oct filters, some content has bass in that range but most does not. Before you list a few consider the number you can list versus the amount of content that exists worldwide and the amount of content with frequencies below 20Hz is very small. You can of course EQ your subwoofer to emphasize what is there. One can visit data bass to see objective measurements and the PB3000 will likely be a bit behind the PB13 Ultra, compared to many other systems there (most of them DIY) the PB13 Ultra falls short. Most music will be fine with extension to 40Hz, but 35Hz works too. Some of the more modern electronic music would require about 25-30Hz. Pipe organs would be about 16Hz. As I have already mentioned the vibrations one feels are not solely from frequencies below 20Hz. You are most welcome to your views, I have already offered mine.
