Need Speakers or Subwoofer to LED TV
Jagstv
chennai
I have bought 43inch LED LG TV. The sound of the TV is good but missing BASS. So I want to add woofer to it. Please suggest good woofer to buy below 7000. can I connect woofer alone to TV because TV speakers are good. i want to add bass to it. Please suggest.
you will not be able to connect only a sub woofer to the TV. You could connect a sound bar directly to the TV. jbl is supposed to have some good range. check them out
If the TV as audio out then you can perhaps connect a subwoofer....provided the audio out settings are not FIXED and can be adjusted as variable....increases output through volume...
Jagstv,
LG which model do you have? What are the Audio out options? Does it have Digital out? or Headphone out?
When you connect a sub or any speaker out from these outputs the internal TV speakers will not work. In other words you will not be able to use both TV speakers and connected subwoofer simultaneously.
