Need suggestion for 7 channel amp
rahuln
Hyderabad, India
Hey,
I have all the pieces of the puzzle to complete my home theater except an amplifier. Here is my setup:
I have 15x13 dedicate room. Oppo BDP-103D will do the duties of preamp and for now I am using my old HK AVR-635 (75W/channel) as amp feeding to Polk R-50/CS-10/R-15 and R-10 in 7.1 setup.
The only problem is HK AVR-635 needs an transformer as it is old 120v unit. I am looking at something to replace it.
Is it possible to replace/modify the power supply in AVR-635 to accept 230v?
Please suggest a good 7 channel amp. My budget is around 50K.
_Rahul.
Try the Emotiva UPA 700. It may just fall in your budget. Contact ashish at Avenue Sound Mumbai. He should be able to get it for you. Alternatively you can order directly from the Emotiva website. The current price is $499.
