Need suggestion for a sub for 200sft room under 40k
Thanks for that leap of faith and buying it as per my suggestion. I appreciate your patience and courage.I personally feel we should encourage local makers for budget purchases like entry level subwoofer.
I have a locally made Telome Audio sub which does the job perfectly.
Some images
Some more
The dimensions of the amp are
19×17×5.5 inches
Sub dimensions:
22×18×16 inches
Weight of the both together is 60 kgs
The amplifier is dual channel. I have asked the person to make so that in case I feel like adding additional sub. It'll be easy. He has tested the amplifier for 4 days on connecting two 15 inch 600 Watt rms subs to the single channel which is 1200 Watt rms total. It performed effortlessly.
My room is 130 sqft. There was problem with my avr. It was giving very low subwoofer output at lfe. In audissy, sub hardly audible. But after completing full audissy, it was okay. I read in somany other forums also with denon avrs. The person who made this is from hyd. He'll not compromise on quality. He'll charge slightly higher than what other local sellers charge but he is really good at what he is doing.
I felt boominess in my room with sub. Room acoustics are not so good in my room and it doesn't come with any dsp as branded subs. So, I have closed the port. After which I felt the bass to be more accurate and tighter. So, it's only my suggestion, if someone wants to go for sub like this for smaller rooms better to go for sealed onc. Subwoofer driver with rms of 500 Watt would really shake the room even if its closed one. Sealed sub with a 15 inch driver may be better. Mine is 12 inch.
Got myself a DIY subwoofer with a 12 inch pioneer ts-1212sw driver which is 500 W rms with an external dual channel class D amplifier with a capacity of 700W rms each channel. This thing just blows my mind.
Raju can you tell me where could you get the amplifier
Review after using it for more than 2 months. No boominess. very neat and clean bass. Placement is all that matters. I had to run Audissy multiple times to get good signal and this is the problem with avr not sub. Removed the cloth and using it like a ported sub as it was made to use for. Thinking of adding one more sub. really happy for the purchase. it changed the entire home theatre experience. Feels like real movie theatre. Felt happy for investing in the entire setup after adding the sub. I wholeheartedly thank the forum member @greendream for the suggestion which Saved a lot of money and time. I thank all the forum members for sharing their experiences and ideas.
How much the total cost of sub and amplifier
Hello friends, I need a suggestion for buying a sub.
My current setup:
Denon 2700h
QA 3050, 3090C and 3020.
Presently room size is 120sqft. May shift the setup to 200 sqft room.
Based on my budget around 35-40k. Have the following options:
Taga TSE 212SE
Polk HTS 10
Mission QX12.
Please suggest. Thank you 🙏
Taga or mission
