20kHz
TAGA 506 Floor Stander has Bass Driver: 2 x 133mm (5.25")How good is taga 506 v2? Will it be compatible with htp 3067. I am planning to buy as my budget is around 45k.
I started with yht 2910. But i learnt assembling is better option.
How good is taga 606 v3 compared with 506 v2? It is 5k more.
Please suggest
Taga 606 Floor Stander has Bass Driver: 2 x 165mm (6.5")
Just Going by the size of bass driver I will go with 606.
And it is worth 5K more just because the package doesn't contain Subwoofer.
If you get a separate sub, you can go with 506!
