Need suggestions to buy 48' LED TV
DJDheeraj
Hyderabad
Hi, I am Dheeraj and I am looking forward to buy a 48' LED TV. Can you guys please suggest me a good model ? My budget is around 65k-75k, an I could come across only one model Sony KLV-48R482B 48" Full HD R482B.
Thanks in advance
There are so many models available with ample features....you need to decide first what all features you need in terms of performance, connectivity etc....most important is warranty..see who offers the most......
Best advice...go to a big electronics store like Vijay Sales / Croma etc and do a side by side comparision..see the TV screen from the side angles if you can view clearly, check the sound and then shortlist the brands that appeal to you....
Toshiba has a 50 inch which is VFM...check it out....also there is Sharp which boast of 4 color technology...all the best...finalise the model and check with your local electronic shop who I am sure will give it more cheaper than a Vijay sales with the same warranty
Thanks in advance
@dheeraj, you can also have a look at panasonic 410 and 610 series in 50inch size,besides LG offers a 49incher for approx 72k.do purchase additional warranties thats very important,also my advice would be that you stick to the big four that is sony, LG, Samsung, Panasonic as they have an established ASC.
Hi Dheeraj,
You can take a look at Panasonic A410D,LG 49LB5510,Samsung 48H5500 for prices around 65k apart from the Sony mentioned by you.(If you dont want a Smart TV)
Hi all
Wat do you think of sony 48r472b I am getting it for reasonable price at a local electronic store.
I have decided to buy Sony and lg only.
What do you think of lg 42ub820t the ultra HD model.
And lg 42 and 49 inches the one you suggested above.
Please tell the difference between IPS and spva(I don't know the name) panel and which one to take.
Thanks in advance.
