New Panasonic Viera X30 - Exciting Features and Look
Thanks, let me also try with USB port. Did you plug it in when the TV is running or it should be switched off/on with the drive ?
Thanks Neeraj
but after updating the firmware does it play formats with dts audio like mp4 and others?
Neeeraj,
I tried to upgrade firmware using sd card and pen drive but it didnt work.
Can you please let me know if I missed anything.
Steps i followed..
1.Switch off TV.
2.Copied SDDL.sec file to sd card/pen drive.
3.plug in sd card/pen drive.
4.Switch on TV
Neeeraj,
Steps i followed..
1.Switch off TV.
4.Switch on TV
Mate, it will not auto update the firmware post insertion of the SD card / USB drive, you will need to go to settings and manually select update firmware....
Switch on TV first, then plug in the card. I updated firmware yesterday... took about 7-8 minutes in total. First it downloads from card to TV, then asks you to switch off the TV and remove the card. Then switch on and wait while it auto-installs.
Could not notice any difference so far. The 2015 version does not play dts sound on mp4, i.e. same as 2014 version in that case.
