New sub help to add
bigfoot426
Brooklyn
Hi first time poster...
I am looking to add a sub to my speaker and amp setup I have currently, and hoping for advice on which to look into more. Im looking for a little extra boom at the lower end for my movies while not sacrificing quality while listening to my vinyls. My room is about 13x20.
Current setup is TT>Rega Brio>Dynaudio Emit
Trying to decide between:
REL T5
SVS SB-2000
Velodyne impact 12"
BK xxls400
Are there others I should look at? Which are the favorites of the above? Anything else I'm missing? I need something that will be ok with my Rega (power, speaker line, etc)
there are many like JL audio etc..
but that depends on the budget as well..
you can do a DiY as well since parts are easy to get for you
Hi Bigfoot426,
Since you are based in US, look at BIC America F12 or H100ii or PL200...these subs are awesome and can go as low as 23/24hz....good enough for movies, gaming and music....12 inch subs....
