new subwoofer taga or paradigm
hello friends, just wanted your suggestions in choosing the right sub-woofer for my home theatre system for my budget around 30-35k
I am using Marantz SR 4002 Amplifier(have copied specs below for ref) and Paradigm CT90 5.1 satellite speakers
Have shortlisted below sub woofer which fits around my budget, need a tight punch/bass for listening to music and watching movies, pls suggest
1)Paradigm PDR100 Subwoofer
2)Velodyne Impact 12" Subwoofer
3)BIC America F12
AUDIO
  • Amplifier Output Details
    80 Watt - 8 Ohm - 20 - 20000 Hz - THD 0.08% - 7 channels (surround)
    105 Watt - 6 Ohm - 20 - 20000 Hz - THD 0.08% - 7 channels (surround)
  • Response Bandwidth
    8 - 100000 Hz
  • Signal-To-Noise Ratio
    105 dB
AMPLIFIER
  • Input Channel Qty
    8
  • Output Channel Qty
    8
  • Output Power / Total
    560 Watt
  • Input Impedance
    47 Ohm
  • Input Sensitivity
    180 mV
AMPLIFIER OUTPUT DETAILS
  • Output Power / Channel
    105 Watt, 80 Watt
  • Output Impedance / Channel
    6 Ohm, 8 Ohm
  • Frequency Response
    20 - 20000 Hz
  • Total Harmonic Distortion (THD)
    0.08 %
  • Channel Type
    surround
  • Channel Qty
    7
Since you are based in Mumbai, try to audition the F12 BiC America....ProAudioHome....new Mumbai....speak to Sagar
Sir, considering all the positive post I have finalised to purchase the BIC America sub-woofer, My living room size is 20 feet x 12 feet and need suggestion whether I should go for F12 or the PL200 , although for PL200 my budget will increase but considering future upgrade for my HT( Marantaz SR4002 AV & Paradigm CT90 5.1 speakers) I want to invest in a quality sub which will entertain me for the long run as well, pls advise
BIC Americas i think is backed with 5 years warranty on speaker n cabinet and 2 years on the amp.....You can use the F12 for now and then later when budget permits go for the PL200.....
I used a H100ii......awesome sub.....if available go for it.....much much better than the F12...
