Prudent111
Hello,
I am planning to buy Norge 1000 Gold to be paired with Norge 125 watts tower speakers. I would be mostly listening to Hindi movie songs from 60s to 2000's, at times classical sourced from .wav or .flac files and occasionally for movies from OTT platforms. Growing up listening to radio, I lean towards clear mids. This is my first purchase into audiophile world. So far I am listening on Sony SRS-D9 active speakers. Have recently added pagaria bluetooth receiver/transmitter to enable wireless listening to it. In future, planning to buy a dedicated DAC that can directly play .wav, .flac, .mp3 files from USB pen drive. I also have Sony DVD Player DVP-SR760H which I use to connect to Sony speakers. presently I am writing .wav files to .cda (Red Book) format by using NCH software to play from this DVD.
Please suggest would Norge be a good combination or should I go for other one. My apprehension with Norge 1000 is that while the it can drive 4 ohms at 100 watts the tower speaker are 125 watts at 4 ohm, which would put strain on amplifier. My basic understanding is that the amplifier watt should be greater than the speakers and the ohms of speaker should be greater than the ampIifier, hope this is correct understanding? I do not want heating problems on Norge set up to spoil these equipments. In the past I have listened to Focal Chora 806 2-way bookshelf speakers, I loved them, but cost is way to high for an entry level audiophile. I can stretch my budget to upto 50,000 for amplifier and speaker together. Also suggest a DAC preferably with ESS9038Q2M or better with direct USB play supporting .wav or .flac files.
Many Thanks.
Many Thanks.
