Onkyo TX-NR686
Kratos420
Hollywood, Florida
I just bought an Onkyo NR686, (my first Onkyo) it sounds great and setup was a breeze. However, when playing any kind of input, HDMI, RCA, USB or wireless I have to set the volume level at a minimum of “45” to get a decent level of sound. Is this a “Onkyo” thing or something else? In most of the video reviews that I’ve seen, the reviewer always had the volume setting at “47” or above. So I am inclined to think that it’s a “Onkyo” thing or my speakers. What I have now is, 2 Jensen twin cone floor standers and a Klipsch center channel, all rated at 8 ohms and all over 25 years old. I am planning on getting a new speaker set which brings me to my main question. Will installing speakers with a nominal rating of 6 ohms provide more volume at a lower setting or does it really make that much of a difference?
Loudness depends on the sensitivity of your speakers.
Your speaker can provide a certain amount of sound pressure when fed 1W. The speaker impedance determines how hard your amp has to work to produce that 1W. A lower impedance speaker demands more current from your amp, making it work harder.
It is common on across all the AVR.. Assuming you have calibrated the speakers already using AVR set-up, and if you switch to dB volume scale, you will fairly know at what volume levels do you play.. Usually the values are between -20 dB to -10dB on my AVR.. ( Denon AVR x 3300, volume starts from -75 dB all the way to + 18dB)..
This volume levels may change on your AVR, depending on your room size & speaker sensitivity..
