Opinion about PHILIPS SOUNDBAR HOME THEATER
amvarma
Hi All,
I am just joined this forum and wanted to know, Philips Soundbar Home theater, it has been around for a while? How is it? Is it worth buying.
Amvarma
Don't settle for such home theater systems. Post your budget here so that we can suggest better ones.
Unless restricted to space please avoid soundbars.The omph factor simply isn't worth it.
If price is no issues and space is,then the Harman Kardon SB16 Soundbar with its wireless sub-woofer makes for good choice.
If you have decided on Philips HTS - 7140/98 its advertised ambisound and 3d makes for a very lame effect.Stay away if you cannot settle for soundbar without dedicated subwoofer.
