Small correction, body is aluminium in both the players but the faceplate in the 80 is made of plastic (finishing looks like metal though). Also 83 is much bigger in size.It is also encased in a plastic body as compared to the aluminum body of 83,
What is the cheapest way to import oppo to India? Which site?
What the heck is so great about this player that isn't in the 150-200$ Bluray players?
Nothing much. The SQ is not audiophile quality. Today BDPs are available for $200 that give good PQ. I think this wasn't the case when the Oppo became famous as a brand. For the extra $$ you get a firmware update every few months that adds support more HD formats and fixes issues with playing them if any. If you get a Sony or Panny, you may be stuck with whatever features (or crippling issues) were released at the time of purchase for the next 5 years.
I think my paypal payment was blocked, nothing to do with the supplier of goods.
Is paypal from India working now?
anyplace in Delhi where one can check out the Oppo BD83 ? Who is the dealer/importer? What's the price ?
Is the player multi region (for DVDs) and all zone (for Blu Ray) ?
What's the price ?
In network streaming you can get most formats to work. I use asset upnp for audio and tversity for video and get them to play. for formats not natively supported you can get them transcoded to a format that oppo will understand and get it to play.
Buddy, were you able to play MKV files using Oppo BDP-83? Does it have a file size limit? Does it seek or does it start from beginning if we try to skip few minutes back or forth? My questions was if it will suffice or does it make sense to purchase a **separate** media player like the WDTV Live to play AVI files etc.
Yes, the oppo plays formats like mkv/avi. I use Tversity for video streaming. There were some issues after the latest firmware (May) when the network streaming stopped working but the newer versions of the software (Tversity) seem to work out of the box.
There are no size limits, I have played 25gb files, the network can be your bottleneck. Also, if you are doing transcoding on the fly, then make sure that your computer is fast enough.
WDTV as discussed earlier has its advantages in terms of convenience, its truly plug and play and consumes lesser power.
The software method of DLNA needs a desktop/laptop on and needs tweaking to get it working.
The advantage of the oppo is a much better upscaler most mkv's come in real odd resolution formats so a good upscaler/convertor helps in giving the best possible picture.
Also, the oppo will decode hd audio which afaik the wdtv or similar (other than the PCH) will only passthrough.
