Kannan,
Thx 4 ur suggestion. I checked playing external videos via USB and they also show the same issue as airtel dtv.
I called up Panasonic engineer and airtel dtv engineer and they both said its not their problem so im stuck:sad:
what next??
thx
abhinav
Sorry!!! couldn't call you back after our call. I was away from Bangalore for a personal emergency....
Please try a factory reset as echo77 is suggesting. I genuinely hope it is a one off issue and it gets resolved with a factory reset. After we spoke, I tried keenly noting for any such issue, but I couldn't find any... it is as normal as it was the first day (touch wood).
Also, did the panny engineer give a visit to your house to see it? If you are getting it even in USB pictures, then it is 120% covered in warranty and they have to correct it or replace the unit (Please insist on them visiting your house).
I will try to come to your house tomorrow or the day after to see it once. Will call you.
Abhinav whether sound quality is good from P42X30D itself or should we go for any home theater. Which home theater u have gone for.
@ Chungs: I am using it in a 11.5 x 12.4 room and it is fairly decent. But you need to keep fiddling with the volume (by reducing) to understand dialogues and to enjoy effects (by increasing). Best option is to have a HT....
I am planning to buy a Onkyo 3400 / 3500 (If I am buying it will mostly be with Abhi only...) ....
Let us know what you decide....
Rdgs/ Baala
