Panasonic E6 - How to connect external speakers?
hfvuser
Delhi/NCR
I am not sure on Anubis post as I don't think the TV has RCA out but only S/PDIF (optical) out. Please try pm him on his post.
IMO
I don't think u can directly connect RCA or 3.5 mm jack to the tv as the TV only has digital optical out put. You need to get a speaker system which accepts optical input and connect a optical audio out cable like Toshiba Toslink cable from tv to the sound system via the digital output port of tv to the speaker. Please note that if ur planning on a optical audio in port sound system it is usually for 10k and above. Cheaper options don't have optical ports
Another option is to get a converter from digital audio optical to rca converters. I am not sure whether u have an optical out to 3.5 mm converters, even though quick search on Google gave some results. But both these converters is a conversion from digital to analogue signal, so it may not give the actual quality sound which the source produces.
Again in my personal opinion the sounds of the TV is pretty decent on normal DTH and pen drive/ smart tv app plays, so not sure whether u actually need a sound out :)
Hope this helps and hope someone like Anubis maybe able to ratify what I have blabbered :D or suggest another option
