Panasonic / LG / Sony - Advice required
sivasubbusn
bangalore
Dear All,
Thanks you all for your wonderful efforts. I have decided to buy a 42'' 3D+LED tv during this festive season and finally narrowed down to the following models with the price. Can you pls. throw some light / suggestion on this to decide the model.
LG: LA6620 - 70k
Panasonic: L42ET60D - 62K
SONY: 42W800A - 74K
I feel Panasonic price is more attractive and PQ also awesome but unable to find out any reviews on this model.
So, can you pls suggest which one is better among this. And also suggest me a shop where I will get the better deal.
Thanks and regards,
Siva
Dear All,
LG: LA6620 - 70k
SONY: 42W800A - 74K
Thanks and regards,
Siva
Well...Panasonic looks great looking at the price coupled with 3 yr warranty. Well...fro reviews n more detailed specs u can check out the Panasonic uk site - VIERA Flat Screen TV - Smart VIERA LED TV - TX-L42ET60B - Reviews - Panasonic UK & Ireland
For detailed n honest reviews here u go:-
1) Panasonic TX-L55ET60 review - TV - Trusted Reviews
2) Panasonic TX-L47ET60B Performance
Both are the same models just different size. The 2nd web link is considered to be the most unbiased n genuine review site.
BTW...all the panny 2013 viera led range has got positive reviewed n few of them like E6 has got stellar reviews.
Going by the review it's a good set...these guys really go technical n find flaws in almost any model...so dont be worried.
Looking at the reviews n the price, I would go for the panny...looks pretty decent. Yes, u r right it's 2D HD/SD PQ would definitely be better then the LG atleast...Sony might be at par.
Dear All,
LG: LA6620 - 70k
SONY: 42W800A - 74K
Thanks and regards,
Siva
Could you tell me where in Bangalore you got the quote of 62K for ET60D?
I searched in Koramangala. Stock was not there and they quoted 75k.
Panasonic and LG both are good models..
i suggest you to ignore SONY W800/ W850 as its strictly for PQ..
W800/ W850 is suffering from clouding issues, Sound Quality is a letdown, UI sucks - MY AIRTEL DTH UI IS FAR BETTER THAN SONY SO CALLED SMART TV UI.. otherwise its a great T.V.
On other-hand Panasonic and LG both have good PQ and Awesome smart features.. you will feel like you have an 42" gadget.
Consider LA6910 OVER LA6620 AS ITS JUST 4k difference.
