Panasonic/SONY/Sharp/Samsung ? need advice
Hi Guys ,
Thanks for suggesting that Takasky is fine with it ,
I have confirmed to stick with pana , but can you tel me one thing
Model LX800
1125 (1080)/60p (HDMI only) Yes
1125 (1080)/50p (HDMI only) Yes
1125 (1080)/24p (HDMI only) Yes
Model LE8
1125 (1080)/60p (HDMI only) No
1125 (1080)/50p (HDMI only) no
1125 (1080)/24p (HDMI only) no
1.) Does it mean LX800 is F HD ,
Since i would be playing blue-ray movies also so would there be noticable difference between them ? ,
As of me i cannot recognize any kinda diff between LE8 and other FD over there @32, specially colors but yeah slightly contrast was more (Slightly differenciated only if both are kept adjacent . )
Might be CD running was not much filled in with content to be recognised ?.
So would it be worth going to LX800 ?
Or should i stick with LE8 and save bucks for other thing s... ( after all recession Time ;-) ...
LX800 is HD ready not full HD-ie. it can accept 1080p & downscale to native 720p.So if you connect Blray,there can be some differences in 1080 & 720p Q.
LX800 will win over LE8 by performance(100Hz )features(1080p ready,24f/s)
UK models are full HD(32in also)
LE8 is better than other LCDs as it has clear panal,it has less blurring(motion) than others(sam) It looks natuarl,sharp & realastic than others.
I suggest you to check LCD TV as below
1."Response time Less than 5 ms"
2. More than 2 HDMI Ports
3. Better Contrast ratio.
4. and preference goes for Sharp,Samsung,Sony & Philips
Boyireddy
