Panasonic TH-L39B6D FHD LED TV
vikod
hyderabad
What do you guys think about this model? i'm on the look out for a 39 - 42' ncher - had zeroed on the LG 42PN5400 - did a demo, and felt the audio output was real bad (need to redo the demo though - not optimal setting @ reliance digital.
Then came across this panasonic model and looked good, (LG @ reliance hyd was retailing @ 37k and pana 39b6d FHD @ 41K) being full hd which obviously is a plus.
tried searching for reviews but do not see much, i guess the same TV in UK is called 39B6B - which seems to have decent reviews on amazon.co.uk.
and the nail in the coffin is this link that i just came across -
Buy Online Panasonic TH-L39B6D FHD LED TV
the price somehow seems unbelievable...
need advice:sad:
go for the panasonic 42e6 or the sony 42w650....both full hd leds....both have got fantastic reviews....take a demo and choose the one which looks good to your eyes...both are good in SD also...
may be you can go for EMI and buy a 42 inches if you have the viewing distance...if you go for leds sony and samsung are good brands...if you cannot afford them then go for lg or panasonic...all the best...
will do a demo of that.. but any idea about the model that i mentioned in the subject of the thread? is it similar to a panny E6 without the frills?
