Panasonic V20 HDD Issue
sairaut
Pune
Hi All,
I have Panasonic V20. I have external 1TB HDD (without power). I tried to connect it to V20 through USB, but V20 does not recognize the HDD. I have lot of Videos and Pictures on that which i am expecting to see on my V20. Is there any specific brand Panasonic V20 Supports for HDD?
Does the spec say u can directly connect 1TB hard drive directly though usb? are you sure the Internal medial player supports HD formats?
Get a media player and play your hd files using that, this is not a problem wit v20 but is rather a feature v20 does not have.
Anyone knows if there is noticable judder in the V20s? And is there any cancellation technique?
In most cases judder can be blamed the source, there's nothing we can do abt it ;) you might wanna try a DLP . Turning off IFC helps in some cases, well i have it always kept off on mine, all the time. If the video was shot in a low frame rate then only CRT's can play it properly.
Thanks Ferrari1976 for the input.
My current HDD is NTFS. So you mean that it only recognize exFAT HDD?
Also what all video formats does V20 Support? How can i upgrade V20 to support the latest formats like MP4 etc?
