Panasonic Viera LED TV feedback
Is Panny 50AS610D a Full HD or HD Ready television?
Screen resolution is mentioned as 1366 x 768 Pixels.(as mentioned in some E-com Sites like Zopper, Indiatimes)
Full Hd must be 1920x1080 Pixels?
Was comparing Panasonic 42AS630(Non 3D) with 42AS670(3D).Major spec difference found are
42AS630
100 HZ BLB
Dual Core Processing
42AS670
1200 Hz BLS
Hexa core processing
Will these spec difference result in overall better PQ and reduction in motion blur.
I watch lot of football and motorpsorts.So planning to pick better one from this as the replacement for my E6 under warranty.
Experts/users please provide a quick input.
42AS630
100 HZ BLB
42AS670
1200 Hz BLS
without a doubt, yes. higher refresh rates do help in reduction of motion blur,this was the reason plasmas had an edge over LED tv's on the motion blur issue, other users can confirm this fact.
I took a look at some 42" plasma TV's today I.e the Samsung and LG ones side by side. I was in for a surprise - everybody's been saying plasmas have better blacks blah blah, but I saw an LED TV that beat the plasmas in that. It was the LG 42LB5820. It beat the Expensive Sony's and Samsung TVs in natural color reproduction and had deeper black levels than either plasma.
Check it out if you are TV shopping. You may need to get the color balance and temperature adjusted to bring out it's magic.
PQ was awesome I'm showroom for lg lb5820. However black levels were not good which is cmom across entry level IPS panels. Not at all a bad set for sure..
