Panasonis Plasma in 40k to 50K plz suggest me.
Natarajkp
Hyderabad
Panasonic Plasma in 40k to 50K plz suggest me.
Hello every one :),
I am Nataraj from hyderabad and i'm planning to purchase panasonic plasma in the price range of rs.40k to 50k so plz suggest me best in that range and also let me know that HT offer is available or not.
Thanks in Advance.....:)
check in ur local showrooms are u finding any difference in semi hd panel 42 inch and full hd panel 42 inch by playing hd files..........mostly u wont...
if yes go for full hd.if no go for semi hd..if intersted in 3d then eventually u have to go for 3d full hd.
42 inch OR 50 inch.which suits ur budget....bigger is better
check and play....just look for the picture quality.no other feuture like usb port/many hdmi port/powerfull sound/3d sound etc etc.......
select the model.....
check any online deal if very cheap compared to showrrom price(in 12/14 month emi u have to go with showrrom)
by the way last time I checked 42X30 42 inch semi hd was around 36k with manufacture warranty online....
Finally bought 50xt50 for Rs.65400 including 2 panny 3D glasses, wireless headset and universal remote. Really loved the video quality n inbuilt speakers sound was really good
Congratulations & welcome to the club... do put some pictures/ detailed review if you get time...
